ผู้เขียน หัวข้อ: Ion Exchange Resin Chemicals, Water Filter Resin Factory, Sales Water Treatment.  (อ่าน 21 ครั้ง)
  • กระทู้: 7622
« เมื่อ: 03 พฤษภาคม 2568, เวลา 23:20:42 น. »
Sales Water filter, Buy Ion Exchange Resin
Ion Exchange Resin Company, Sales Ion Exchange Resin,
Water Filter Resin Factory, Water Filter Resin Production
8888_Ion Exchange Resin by PKSN_start_03052025
Water Filter, Ion Exchange Resin, Ion Exchange Resin, Ion Exchange Resin, Water Filter Resin, Water Filter Resin Ion Exchange Resin, Ion Exchange Resin, Ion Exchange Resin Anion Exchange Resin, Anion Exchange Resin Cation Exchange Resin, Cation Exchange Resin Mixed Ion Exchange Resin, Mixed Ion Exchange Resin
Alum production, Alum distribution, Alum import, Alum export,
Alum factory, Thai alum, Industrial alum Production of cloudy alum,
Distribution of cloudy alum, Import cloudy alum, Export cloudy alum,
Cloudy alum factory, Thai cloudy alum Production of clear alum,
Distribution of clear alum, Import clear alum, Export clear alum,
Clear alum factory, Thai clear alum Production of alum powder,
Distribution of alum powder, Import alum powder, Export alum powder,
Alum powder factory, Thai alum powder Production of alum pellets,
Distribution of alum pellets, Import alum pellets, Export alum pellets,
Alum pellets factory, Thai alum pellets Production of alum lumps,
Distribution of alum lumps, Import alum lumps,
Export alum lumps, Alum lump factory,
Thai alum lumps Production of alum lump no. 1,
Distribution of alum lump no. 1, Import alum lump no. 1,
Export alum lump no. 1 Production of alum lump no. 2,
Distribution of alum lump no. 2, Import alum lump no. 2,
Export alum lump no. 2 Produce Alum Block No. 3,
Distribute Alum Block No. 3, Import Alum Block No. 3,
Export Alum Block No. 3, Produce Alum Water,
Distribute Alum Water, Import Alum Water,
Export Alum Water, Alum Water Factory, Thai Alum Wate
You can inquire about product information, request product samples and order products at Thai Polychemical Co., Ltd. (Water Treatment Chemicals)
Thai Poly Chemicals Company (Water Treatment Chemicals)
TPCC PKSN RESIN THAILAND
Ion exchange.
The ionic exchange is carried out by means of a polymer in the form of tiny spheres that are capable of exchanging particular ions for other ions, in a solution that passes through them. These synthetic gel spheres are called "Ion Exchange Resins". This exchange capacity is also observed in various natural systems, such as soils and living cells. Synthetic resins are not only used for water purification, but also for various other applications that include the separation of some elements. In water purification, the main goal is to soften the water or remove the mineral content. The water is softened by the use of a resin that contains sodium cations (Na+), and exchanges them for calcium Ca2+ and magnesium Mg2+ (hardness). As the water passes through the resin, Ca uptake increases2+ and Mg2+ until the resin is saturated, at this point it is necessary to regenerate the resin, charging it again with Na+.
The processes that use ion exchange are the following:
Water softener (hardness removal)
De-alkalization (remove carbonates)
Decationisation (removal of all cations)
Demineralization (removal of all ions)
Mixed bed (Nitrates and demineralization)
Remove metals
Resin types are often abbreviated as:
SAC: strong acid cation exchange resin
WAC: weak acid cation exchange resin
SBA: strong base anion exchange resin
AMB: weak base anion exchange resin
Resin filter
Resin filter is a substance that looks like yellow-orange fish eggs, which is suitable for filtering out hardness mixed with water. It is a substance that is very necessary for water filters when filtering tap water or groundwater. The main function of the water filter resin is to remove limestone and filter out the hardness of the water. This allows you to drink and use the water without fear of harm to the body. It also helps to make the water soft on the tongue and not rough on the throat.
What is a resin filter?
Resin filter is a polymer that cannot be dissolved in water. It will be in the form of small spheres like fish eggs with a diameter of about 1-2 millimeters and is yellow in color.
Each brand of resin filter will have a different color, but it is still a clear golden yellow.
The resin works by absorbing calcium and magnesium from the water that flows through the resin filter.
As the water flows through the resin, it will release sodium.
Resin filters are suitable for use in water filters for consumption.
What are the properties of resin filters?
1. Resin filters help filter out the hardness of water, allowing you to drink water without harshness.
2. Resin filters help remove limestone mixed in water, which is not good for the body and can have an adverse effect on the kidney system.
3. Resin filters help remove solutions in the form of ions, such as bicarbonate, all minerals mixed in pure water.
More information about Resin water filters (Ion Exchange Resin)
You can inquire about product information directly at Thai Polychemical Co., Ltd.
Currently distributed by Thai Polychemical Co., Ltd. are as follows
ACID (กรด)
Acetic Acid (กรดอาซีติก)
Boric Acid (กรดบอริก)
Citric Acid (กรดมะนาว)
Formic Acid (กรดฟอร์มิก)
Hydrochloric Acid (กรดเกลือ)
Hydrofluoric Acid (กรดกัดแก้ว)
Nitric Acid (กรดไนตริก)
Phosphoric Acid (กรดฟอสฟอริก)
Sodium Bisulphate (กรดเกลือแห้ง)
Sulphamic Acid (กรดซัลฟามิก)
Sulphuric Acid (กรดกำมะถัน)
Specialty Acid (กรดชนิดพิเศษอื่นๆ)
BASE, SALT (เบส,เกลือ)
Ammonium Hydroxide (แอมโมเนียน้ำ)
Calcium Carbonate (แคลเซียมคาร์บอเนต)
Calcium Chloride (แคลเซียมคลอไรด์)
Calcium Hydroxide (แคลเซียมไฮดรอกไซด์)
Calcium Nitrate (แคลเซียมไนเตรต)
Calcium Oxide (แคลเซียมออกไซด์)
Caustic Soda (คอสติกโซดา, โซดาไฟ)
Diatomaceous Earth (ดินเบา)
Ferrous Sulphate (เฟอรัสซัลเฟต)
Hydrated Lime, (ปูนไฮเดรตไลม์)
Quick Lime (ปูนขาว, ปูนร้อน)
Soda Ash Dense (โซดาแอชเดนส์)
Soda Ash Light (โซดาแอชไลท์)
Sodium Bentonite (โซเดียมเบนโทไนท์)
Sodium Bicarbonate (โซเดียมไบคาร์บอเนต)
Sodium Borate (โซเดียมบอเรต)
Sodium Carbonate (โซเดียมคาร์บอเนต)
Sodium Chloride (โซเดียมคลอไรด์)
Sodium Hydroxide (โซเดียมไฮดรอกไซด์)
Sodium Sulphate (โซเดียมซัลเฟต)
Sodium Sulphite (โซเดียมซัลไฟต์)
Sodium Sulphide Red (โซเดียมซัลไฟด์ เกล็ดแดง)
Sodium Sulphide Yellow (โซเดียมซัลไฟด์ เกล็ดเหลือง)
Specialty Base (สารเบสชนิดพิเศษอื่น)
Specialty Salt (เกลือชนิดพิเศษอื่นๆ)
ALUM (สารส้ม มอก.165-2554)
Aluminium Sulphate 8% (สารส้มน้ำ 8%)
Aluminium Sulphate 16% (สารส้ม ขุ่นผง, ขุ่นเม็ด, ขุ่นก้อน)
Aluminium Ammonium Sulphate (สารส้ม ใสผง)
Aluminium Ammonium Sulphate #1 (สารส้ม ใสก้อน เบอร์ 1)
Aluminium Ammonium Sulphate #2 (สารส้ม ใสก้อน เบอร์ 2)
Aluminium Ammonium Sulphate #3 (สารส้ม ใสก้อน เบอร์ 3)
Aluminium Potassium Sulphate (สารส้มใสโพแทสเซียม)
Potash Alum Crystal (สารส้ม โพแทสอะลัม)
ผลิตสารส้ม, จำหน่ายสารส้ม, นำเข้าสารส้ม, ส่งออกสารส้ม, โรงงานสารส้ม, สารส้มไทย, สารส้มอุตสาหกรรม
ผลิตสารส้มขุ่น, จำหน่ายสารส้มขุ่น, นำเข้าสารส้มขุ่น, ส่งออกสารส้มขุ่น, โรงงานสารส้มขุ่น, สารส้มขุ่นไทย
ผลิตสารส้มใส, จำหน่ายสารส้มใส, นำเข้าสารส้มใส, ส่งออกสารส้มใส, โรงงานสารส้มใส, สารส้มใสไทย
ผลิตสารส้มผง, จำหน่ายสารส้มผง, นำเข้าสารส้มผง, ส่งออกสารส้มผง, โรงงานสารส้มผง, สารส้มผงไทย
ผลิตสารส้มเม็ด, จำหน่ายสารส้มเม็ด, นำเข้าสารส้มเม็ด, ส่งออกสารส้มเม็ด, โรงงานสารส้มเม็ด, สารส้มเม็ดไทย
ผลิตสารส้มก้อน, จำหน่ายสารส้มก้อน, นำเข้าสารส้มก้อน, ส่งออกสารส้มก้อน, โรงงานสารส้มก้อน, สารส้มก้อนไทย
ผลิตสารส้มก้อนเบอร์1, จำหน่ายสารส้มก้อนเบอร์1, นำเข้าสารส้มก้อนเบอร์1, ส่งออกสารส้มก้อนเบอร์1
ผลิตสารส้มก้อนเบอร์2, จำหน่ายสารส้มก้อนเบอร์2, นำเข้าสารส้มก้อนเบอร์2, ส่งออกสารส้มก้อนเบอร์2
ผลิตสารส้มก้อนเบอร์3, จำหน่ายสารส้มก้อนเบอร์3, นำเข้าสารส้มก้อนเบอร์3, ส่งออกสารส้มก้อนเบอร์3
ผลิตสารส้มน้ำ, จำหน่ายสารส้มน้ำ, นำเข้าสารส้มน้ำ, ส่งออกสารส้มน้ำ, โรงงานสารส้มน้ำ, สารส้มน้ำไทย
FLOCCULANT, FILTER AID (สารตกตะกอน, สารกรองน้ำ)
Activated Carbon (ผงถ่านกัมมันต์)
Anthracite (ผงกรอง แอนทราไซท์)
Water Purified Resin (สารกรองน้ำ, เรซินกรองน้ำ, สารกรองน้ำเรซิน)
Ion Exchange Resin (ไอออนเอกเชนซ์เรซิน, เรซินแลกเปลี่ยนประจุ)
Anion Exchange Resin (เรซินกรองน้ำ ประจุลบ)
Cation Exchange Resin (เรซินกรองน้ำ ประจุบวก)
Mixed Ion Exchange Resin (เรซินกรองน้ำ ประจุผสม)
Aluminium Chlorohydrate (อลูมิเนียม คลอโรไฮเดรต)
Diatomaceous Earth, Diatomite (ดินเบา)
Ferric Chloride (เฟอริคคลอไรด์)
Polyaluminium Chloride 10%, PAC10% (แพคน้ำ)
Polyaluminium Chloride 30%, PAC30% (แพคผง)
Water Decoloring Agent, WDA (สารตกตะกอนประสิทธิภาพสูง)
COAGULANT (สารเร่งตกตะกอน)
An-ionic Polymer (โพลิเมอร์ ประจุลบ)
Cat-ionic Polymer (โพลิเมอร์ ประจุบวก)
Polyacrylamide (โพลีอคริลาไมด์)
CLORINATION, CHELATE (คลอรีน, สารฆ่าเชื้อ, สารจับโลหะ)
Benzalkonium Chloride, BKC (เบนซัลโคเนียมคลอไรด์)
Biocide (ไบโอไซด์)
Calcium Hypochlorite (แคลเซียมไฮโปคลอไรท์)
Chlorine 10% (คลอรีนน้ำ 10%)
Chlorine 65%, 70%, 90% (คลอรีนผง, คลอรีนเกล็ด, คลอรีนเม็ด)
Chlorine Dioxide Solution (คลอรีนไดออกไซด์)
Defoamer (สารลดฟอง)
EDTA 2Na (อีดีทีเอ 2 โซเดียม)
EDTA 4Na (อีดีทีเอ 4 โซเดียม)
HEDP, Phosphonates (Dequest) (เอชอีดีพี)
Hydrazine Hydrate (ไฮดราซีนไฮเดรต)
Hydrogen Peroxide (ไฮโดรเจนเปอร์ออกไซด์)
Glutaraldehyde (กลูตารอลดีไฮด์)
Potassium Permanganate (ด่างทับทิม)
Sodium Hypochlorite (โซเดียมไฮโปคลอไรท์)
Specialty Chemicals (Other special water treatment chemicals)
More information about Water Treatment Chemicals
Specialty Chemicals (สารเคมีบำบัดน้ำ ชนิดพิเศษอื่นๆ)
ข้อมูลเพิ่มเติม เกี่ยวกับ เคมีภัณฑ์บำบัดน้ำ (Water Treatment Chemicals)
สามารถสอบถามข้อมูลสินค้า ได้โดยตรง ที่บริษัท ไทยโพลีเคมิคอล จำกัด
PKSN RESIN THAILAND
Keywords : Water filter, Ion Exchange Resin, Ion Exchange Resin,
สารกรองน้ำ, Ion Exchange Resin, เรซินแลกเปลี่ยนประจุ,
ไอออนเอ็กซ์เชนจ์เรซิน, สารกรองน้ำเรซิน, เรซินกรองน้ำ
  • กระทู้: 7622
Re: Ion Exchange Resin Chemicals, Water Filter Resin Factory, Sales Water Treatment.
« ตอบกลับ #1 เมื่อ: 05 พฤษภาคม 2568, เวลา 17:31:31 น. »
  • กระทู้: 7622
« ตอบกลับ #2 เมื่อ: เมื่อวานนี้ เวลา 19:14:12 »
